ACH
  1. I’m having trouble getting measured horizontal single-axis tracker POA values into a Met file by ASCII import in 6.75. The restated POA values in the resulting Met file do not match what is in the ASCII source file. All relevant information has been entered--horizontal inclination of 0, azimuth of 0, angle of rotation limits -60 to 60deg. When I view the Met file “Used parameters,” I see InclMin/Max = 10.0/80.0, and AzimMin/Max =-60.0/60.0. Is there a place where this can be modified? Is it within the Met file input, or within the project file? From PVSyst6 Help: Plane Orientation, we see “…..During the data analysis and simulation comparisons, you will be able to use either the original values or a recalculated plane irradiation. At this stage, plane orientation may be slightly modified, but big changes are not advised as the tilted plane irradiation looses some information with respect to horizontal true measurements.” Thank you!
