It is currently Mon Jan 24, 2022 9:58 pm
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Thu Aug 26, 2021 7:58 pm
I have imported a 3D shading scene (.PVC file from PVCase) into a PVsyst simulation based on mono-facial c-Si modules and single-axis trackers.
If I model the large array as the field type "Tracking, horizontal axis N-S", can PVsyst model shading losses from both the E/W slope and the N/S slope? Or only one slope direction?
Thank you!
-Dan, USA
PostPosted: Fri Aug 27, 2021 3:52 pm
E-W slope can be captured. When backtracking, the N-S tilt angle must be the same for all trackers. So E-W yes, N-S no.
PostPosted: Fri Aug 27, 2021 7:36 pm
Thanks for the quick response @dtarin.
Am I correct in the following thinking: if the N/S slope is consistent across the entire array, some N/S shading losses will be captured. But it will be a rough approximation of the N/S losses as a single slope angle is applied to all trackers. No undulation is captured.
PostPosted: Fri Aug 27, 2021 8:17 pm
Correct. You can use a weighted average of the N-S slopes to capture overall N-S slope, which may be a gain or loss.
PostPosted: Fri Aug 27, 2021 8:23 pm
I appreciate the help! And glad that PVsyst v7 has this capability.
-Dan
PostPosted: Fri Oct 22, 2021 8:04 pm
Hi, i have exported 3D shading scene from PVcase to PVsyst 7.2.6 and it worked well even if backtracking is kept active. I have different tracking tilts (following N-S slopes of the terrain) and different E-W slopes as well.
Do you think this may captured N-S and E-W slopes on the same time?
Thanks.
