It is currently Sun Jul 25, 2021 2:32 pm
PostPosted: Tue May 04, 2021 12:41 pm
I hope to get an answer for my simple question
I want to design a PV system with two sperate fields with same orientation , the first field is 118.8 KW with100KW Huawei inverter and the second field is 74.7 KW with 60KW Huawei inverter.
The design is meant for a factory which has two separate roofs but the load profile is for both roofs for that reason I want to design two parts with two different power ratings together.
Is there any possibility to design such a system with two different PV and inverter powers in PVsyst ?
Is there any possibility to get help please from PVsyst team or from other Colleagues
PostPosted: Tue May 04, 2021 6:16 pm
You can have them both in the same project by defining two subarrays under system, or you can model them separately in 2 different variants.
PostPosted: Wed May 05, 2021 3:59 pm
Thank you so much, but can you Please give further explanation about how I can define model them separately in 2 different variants.
