Hello everyone,
I'm working in a 50 MWp plant in a difficult ground. I made the layout on sketchup (Skelion) with one axis trackers. Obviously, the trackers has a different slope angle (-3º to 5º aproximately) but the same azimut (0º).
So, I have 2 different problems:
- 1st: When i drop the trackers on de ground coplanar to the surface, PVSyst give a warning because the trackers haven't the same orientation. I made a test only with 4 trackers and PVSyst give the same warning.
- 2nd: If I drop de trackers without rotation, I can simulate the shades, but the problem is PVSyst dont recognize the backtracking.
I don't know if I explained right but i need help.
Best Regards, and thank you.
