It is currently Wed Oct 28, 2020 7:03 am
PostPosted: Wed Aug 21, 2019 5:14 am
PVsyst v6.83: I see a Hidden Parameter for "Maximum PnomRatio for inverter sizing" but not for "Minimum PnomRatio for inverter sizing". Is there a technical reason why the latter is missing? Is there some other way to set the latter using some other parameter(s) in PVsyst (hidden or not)?
PostPosted: Thu Aug 22, 2019 12:01 am
My guess is that it has to do with equipment safety and protecting the inverters. A low pnom ratio might not function the most efficiently, but I dont think it's going to break the inverter, whereas too high of a pnom ratio can. Most inverter manufacturers only list max ratios (when they do list them) and not min ratios.
PostPosted: Fri Aug 23, 2019 8:53 pm
v6.83: I found the relevant hidden parameter: Verifications on Grid systems\The Inverter power is strongly oversized
