It is currently Fri Feb 26, 2021 3:40 am
PostPosted: Thu Mar 28, 2019 5:24 pm
Hi folks,
I'm modelling a simple grid-connected PV system and have added a battery under the "weak grid" scenario.
In this location however, it is not permitted to export any power back to the grid. When I try to set a limit using Energy Management > Grid Power Limitation, it does not allow me to set the grid power limitation to anything less than 1kW.
The manual does not suggest that there is a requirement for grid export to be >0.
Can anyone confirm if this is indeed the case, whether I'm just doing something wrong, or is this a bug?
PostPosted: Wed Apr 17, 2019 9:35 am
Perhaps you are using an old version.
In the Weak grid definitions you have this option:
Group "Operating conditions", checkBox "Allows solar injection into the grid."
PostPosted: Wed Apr 17, 2019 10:00 am
Thanks André - I had indeed failed to spot that checkbox even though it was obvious once you pointed it out.
