It is currently Fri Sep 25, 2020 8:40 am
PostPosted: Tue Dec 04, 2018 7:59 pm
I'm having an issue simulating an inverter with 4 MPPTs. The thing is that they are unbalanced, while when "Unbalanced MPPT" option is ticked in "Additional Parameters/Secondary Parameters" of the inverter, only two MPPTs can be defined.
Please let me know how to simulate such inverters?
PostPosted: Thu Jan 10, 2019 1:14 pm
Should I conclude it's not yet possible to simulate such inverters?
PostPosted: Wed Jan 16, 2019 3:17 pm
I am facing the same problem. Unable to define an unbalanced inverter with 4 MPPTs.
Can the PVSyst team help please?
PostPosted: Fri Feb 15, 2019 11:20 pm
The "Unbalanced" feature is a very special mode, only available for 2 MPPT imputs with very dissymetric inputs.
When you have more than 2 MPPT inputs, you cannot define this mode and its very specific behaviour.
But you can always define Sub-arrays of different powers on each MPPT. In this case you should use the "Power sharing" option for attributing a given PNom to each MPPT input.
See the help "Project design > Grid-connected system definition > Multi-MPPT inverters: power sharing" for further details.
