It is currently Tue Sep 22, 2020 3:13 am
PostPosted: Thu Mar 16, 2017 2:03 am
I would like to know if there is any possibilities to design an object of curved area such as not a flat area in the PVsyst and place the the PV panels on top of the curved area.
If yes, can please let me know how can I do it?
Thanks
PostPosted: Wed Mar 22, 2017 4:05 pm
In PVsyst you can define sub-arrays for at most 8 orientations.
However this is not possible with stand alone systems yet.
PostPosted: Fri Apr 07, 2017 6:41 pm
abdulrahman95 ,
Is this what you mean by curved suface?
You can create a ground object which matches the terrain, then create a zone of tables/modules on top of the ground object, and then select position tables on scene. This doesnt work for every PV field (ie tracker).
PostPosted: Thu Feb 27, 2020 6:29 pm
I would also like to design a curved system, so I want to know if i can give a module tilt angles in two directions. Along y-z and along x-z?
PostPosted: Wed Mar 04, 2020 11:02 pm
Yes, if you define a "table" or an array of "tables", you have the opportunity of giving a slope to the baseline of your table.
However this will change the orientation of your plane. See the FAQ "With sheds on a tilted roof, PVsyst changes my orientation"
