It is currently Sun May 26, 2019 5:29 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Mon Mar 13, 2017 12:56 pm
Dear André,
I am testing now the calculation for several years, and the results that I got in batch simulation are not the same than I got by changing the year of simulation in "Ageing" tool.
In "batch simulation", I have specified Degradation-> year of simulation", and then in the csv batchparams file I have introduce the years I want to simulate, but the Energy Injected into Grid that I obtain after batch simulation is sliglthly higher than the results I got by changing the year of simulation in "Ageing" tool.
What can be wrong? Is the batch simulation taking into account the mismatch increase due to degradation?
PostPosted: Tue Aug 08, 2017 7:49 am
Hi All,
Can anyone clarify the below:
1. What is "year 0" meant to be?
2. What degradation factor is employed for each year? For instance, if I specify year as '1' for a simulation is the degradation loss for that simulation equal to the default degradation loss you would see in the 'Ageing' menu when you select year 1?
I would really appreciate a bit more guidance material on batch simulation in general.
PostPosted: Fri Aug 18, 2017 3:33 pm
Does anyone know if the mismatch growth is included in the batch simulation? The module degradation is easy to show (even by using other params, as it is linear), but the mismatch growth will reduce production by an additional 2-3% over 20 years, needs to be included in the batch parameters list.
PostPosted: Tue Sep 19, 2017 12:22 pm
Quote:
Hi All,
It would be wonderful if someone from PVsyst could clarify these issues.
viewtopic.php?f=4&t=2754
Evenmore, if you set RMS dispersion values for Isc and Voc to zero, the batch calculation for Energy injected into grid is zero for all the years!!!
Sinceresly, I have lost my hopes and I don't know what to do about this.
PostPosted: Mon Mar 12, 2018 5:11 pm
Hi,
By default, PVsyst considers the average degradation loss throught the whole year. So, if you put degradation loss of 0,4%/year, for year 1, it will consider degratadion losses of 0,2% (starting the year with no degradation losses at all, since the modules are brand new, and ending the year with 0,4% losses, thus averaging 0,2%).
Year 0 means it will not consider any degradation losses. So if want to make a batch simulation for eg. 10 years and you use 1 to 10, PVsyst will consider the average losses throught each year. If you want to change for the losses in the beggining of each year, you should use 0 to 9.
Best regards,
Rafael
PostPosted: Mon Mar 12, 2018 5:23 pm
Regarding the RMS dispersion values, this is strange, because I allways set them zero and it works just fine...
PostPosted: Fri Mar 16, 2018 12:42 pm
Quote:
From version 6.60, the Degradation (year number for a simulation and degradation parameters) is indeed part of the parameters you can use/modify in the batchs.
Has the growth of mismatch been included as well, or just the aging?
Thanks
PostPosted: Wed Mar 21, 2018 3:14 pm
Growth of mismatch is also included! =)
PostPosted: Wed Apr 11, 2018 8:37 am
Hi,
It would be helpful if we can include active power limitation parameters in batch simulation.
_________________
Praveen Sadh
PostPosted: Sat Mar 30, 2019 7:00 am
Yes, it would be useful.
