It is currently Sat Oct 31, 2020 6:58 pm
PostPosted: Wed Jan 08, 2020 8:42 pm
Hi There,
I recently updated to PVSyst 6.8.5 in hopes of using the built in spectral adjustment for first solar modules (FS6). I have re-downloaded the weather file from solaranywhere TMY in V3.2 and V3.3 with relative humidity data, however when I import the new meteo file into pvsyst it does not recognize the relative humidity component, therefore I cannot use the spectral adjustment section of detailed losses.
Any suggestions for how I can remedy this problem?
I am importing the SA TMY in PVSyst via "Meteo Database > Known Format" using "SolarAnywhere Hourly" as the external data source. Perhaps it needs to be a custom format?
Thanks,
Luke
PostPosted: Mon Feb 10, 2020 7:08 pm
I would suggest using a custom format, I did not have success either with the method you tried.
cron
