Quote:
Hi,
I can't import meto data from PVGIS because when I try, a following error occurs: "The columns for the dates are not defined or not sufficient".
It doesn't matter which database or which site I choose. Curiously, I have recently imported the PVGIS data and no problem occurred. However, then I used an older PVSyst version (I think 6.80) than now (6.85).
I also imported the data directly from the PVGIS website but when I tried to use them, the error occured again.
Could you tell me what the error source can be?
Thanks in advance!
I have the same problem!
PVsyst team, please clarify what we have to do to fix it!
Thanks!
