It is currently Fri Sep 24, 2021 7:24 pm
PostPosted: Tue Nov 01, 2016 7:08 pm
I'm trying to run batch simulations for N-S single axis trackers with a tilt of zero. All I want to do is vary the pitch. In the Parameter Specification, 3D shadings parameter I select Pitch E-W between trackers and backtracking activated. I did notice that the parameter word "Backtraked" had been misspelled in the output file.
I get the message: Warning: The shading table has not been computed in the results
I ran this in batch mode with just one data point for the pitch:
PVsyst simulations Batch mode;;
Simulation parameters and results;
File Created on 01/11/16 10:24;;
Project ;;;Sample PVSyst;;
Variants based on;;VC2;ATI_Duratrack_HZ 2.1 MW DC;;
Ident;Trackers;Backtraking;Simul;Error;E_Grid;
;Pitch EW;;Comment;;MWh;
;[m];Y/N;;;;
SIM_1; 4.00;Y;ATI_Duratrack_HZ 2.1 MW DC ;Warning: The shading table has not been computed;4082;
Thanks for your time,
Mike Reed
PostPosted: Thu Nov 17, 2016 12:16 am
This error message "The shading table has not been computed" appears here by mistake.
In fact the shading table is correctly computed at the beginning of the simulation, which arises after this check. This should be corrected in the next versions.
PostPosted: Tue Feb 20, 2018 11:01 pm
I had the same error "Warning: The shading table has not been computed" in Version 6.68 too.
Though it says, the shading table has not been computed, it actually did.
You can verify this by checking the option "produce a pdf report" and verify the loss calculation on the detailed loss section, where it actually accounts for shading.
PostPosted: Tue Dec 01, 2020 8:49 pm
Did this bug ever get fixed? Im still getting this error in v7.1
PostPosted: Fri Jul 23, 2021 12:47 am
Same here, at version 7.2 and the error message is still going strong.
