It is currently Mon Jun 21, 2021 2:26 pm
PostPosted: Sat Jun 27, 2020 8:16 pm
my weather station is reporting Solar Radiation every minute in W/m2.
I want to calculate daily & Monthly PR.
How do I use my W/m2 (resolution is in a minute) into the following formula (GlobInc)
PR = E_Grid / (GlobInc * Pnom)
Please help.
Following what it looks from my weather station Solar Radiation sensor. (minute wise)
PostPosted: Tue Jun 30, 2020 7:31 pm
Same procedure for daily and monthly calculation:
1. Get total energy output of plant for time period, Egrid (in kWh, MWh, etc)
2. Calculate hourly average of irradiance
3. Use basic calculation E_Grid/(Sum_of_hourly_POA*DC_Plant_Size)
Example:
Egrid = 4800 MWh
DC size = 2990 kW
Sum of hourly POA = 1940kWh/m^2
(4800*1000)/(2990*1940) = 82.7%
PostPosted: Sat Aug 08, 2020 7:28 pm
If your original data are measured in the horizontal plane, for calculating the GlobInc, you have to use a transposition model.
You can use PVsyst for that.
- Import your Irradiances data file using "Databases > Import Meteo Data > Custom file". When you are here press F1 for the procedure.
NB: PVsyst only works in hourly values. During the import process, it will accumulate your minutes data into hourly values.
- In "Databases", open "Meteo Tables and Graphs".
Here you can see a table of all your data in hourly, daily or monthly values. You can get the values "Global tilted plane", which is indeed GlobInc or POA.
