It is currently Tue Sep 22, 2020 6:58 pm
PostPosted: Thu Feb 27, 2020 6:33 pm
I would like to put PV on a curved surface but i can work out how to give it tilt angles in two directions. Any help would be appreciated.
PostPosted: Wed Mar 04, 2020 10:53 pm
Create the curved surface, import into pvsyst as ground data, drop modules onto the curved surface (under edit > set auto altitude). Use a .csv file with coordinates X, Y, Z (in meters) which define your surface.
PostPosted: Sun May 24, 2020 8:06 pm
You cannot define curved surfaces in PVsyst.
You have to create a set of planar surfaces, and use the option "Orientation > Several orientations".
However be aware that each orientation should be treated independently (on a different inverter MPP input).
You can eventually mix 2 orientations (the orientations #1 and #2) on one MPP input.
In you case you have to do some approximations.
PostPosted: Sun May 24, 2020 8:09 pm
By curved surface I meant import ground data (.csv) which approximates a curved surface to give his modules tilt and baseline slope.
PostPosted: Tue Jun 09, 2020 10:28 pm
Yes you can define a terrain by (X,Y,Z) coordinates.
See the help "Project design > Shadings > Near Shadings: Import > CSV Ground data"
And you can distribute PV tables on it.
