It is currently Wed Dec 02, 2020 2:25 am
PostPosted: Mon May 07, 2018 11:57 am
Hi,
Is there a way to use "Save to PDF" function without locking the PDF? It would very helpful if I can disable this so I can compile the pdf reports in one file.
Else, can you provide the password to unlock the pdf?
Thank you.
PostPosted: Sun May 20, 2018 12:13 am
No sorry, the PDF provided by PVsyst are now closed for avoiding manipulations of results.
PostPosted: Tue Jun 05, 2018 9:15 pm
We'll allow document assembly in the generated PDF file, starting from PVsyst version 6.74.
So you will be able to include the PVsyst report inside other PDF documents !
PostPosted: Wed Sep 11, 2019 11:33 pm
Quote:
Has this been implemented? We have Version 6.77 installed but are not able to combine PDF files. This is an important issue because some proposals need to be submitted as a single PDF.
PostPosted: Fri Nov 01, 2019 4:59 pm
I have been able to get around this problem by using Print > Adobe PDF instead.
