It is currently Mon Sep 21, 2020 3:37 pm
PostPosted: Sun Sep 30, 2018 4:20 pm
I've tried using different modules to attain different results, but the "PV loss due to temperature" is always 10%. The site is located in South America, Brazil.
As recommended, I am not going to mess with the pv modules specs, but I believe this might be a limitation being caused by the the default parameters set by PVSyst.
If it is indeed a hidden parameter that must be changed in order to attain accurate results, please help me change it as well as recommend parameters that are used in Brazil.
Thank you!
PostPosted: Wed Oct 17, 2018 10:27 pm
There is no specified limit here.
The Temperature loss is related to the muPmpp temperature coefficient of your modules, and the array temperature TArray.
It is evaluated using the one-diode model and the thermal model described in the help "Project design > Array and system losses > Array Thermal losses"
