It is currently Fri Sep 25, 2020 12:21 pm
PostPosted: Thu Sep 27, 2018 2:22 am
I recently was in need of exporting one year worth of hourly humidity data (from meteonorm 7.2) and couldn't find a way to do it directly. I know how to export these kind of data for other parameters (for example GHI, could save a hourly file during simulation) but couldn't find the humidity parameter to add to the result export file. I ended up exporting each month separately from the meteo data graphs tool (that doesn't allow for one year hourly graph/export). Is there a way to do it?
Thanks in advance and best regards
PostPosted: Wed Oct 17, 2018 10:40 pm
You cannot export Meteonorm data.
Meteonorm is also a software, sold as such.
By contract with the Meteonorm team, the use of the Meteonorm data implemented in PVsyst is reserved to the internal use within PVsyst. If you need data for other uses you should buy the Meteonorm software.
PostPosted: Mon Oct 22, 2018 6:41 am
Thank you for the clarification.
It was to calculate First Solar spectral effect but actually that became possible directly in PVsyst now, so we will not need it anymore.
Thanks for the good work on improving the software.
Best regards
