https://forum.pvsyst.com/
Curved area designing on PVsyst
https://forum.pvsyst.com/viewtopic.php?f=3&t=2762
Page 1 of 1
Author:  abdulrahman95 [ Thu Mar 16, 2017 2:03 am ]
Post subject:  Curved area designing on PVsyst
I would like to know if there is any possibilities to design an object of curved area such as not a flat area in the PVsyst and place the the PV panels on top of the curved area.
If yes, can please let me know how can I do it?
Thanks
Author:  AndrĂ© Mermoud [ Wed Mar 22, 2017 4:05 pm ]
Post subject:  Re: Curved area designing on PVsyst
In PVsyst you can define sub-arrays for at most 8 orientations.
However this is not possible with stand alone systems yet.
Author:  dtarin [ Fri Apr 07, 2017 6:41 pm ]
abdulrahman95 ,
Is this what you mean by curved suface?
You can create a ground object which matches the terrain, then create a zone of tables/modules on top of the ground object, and then select position tables on scene. This doesnt work for every PV field (ie tracker).
Author:  AJCarr [ Thu Feb 27, 2020 6:29 pm ]
I would also like to design a curved system, so I want to know if i can give a module tilt angles in two directions. Along y-z and along x-z?
Author:  AndrĂ© Mermoud [ Wed Mar 04, 2020 11:02 pm ]
Yes, if you define a "table" or an array of "tables", you have the opportunity of giving a slope to the baseline of your table.
However this will change the orientation of your plane. See the FAQ "With sheds on a tilted roof, PVsyst changes my orientation"
https://www.phpbb.com/
