It is currently Tue Sep 22, 2020 3:32 am
PostPosted: Thu Mar 17, 2016 2:49 am
Hi all,
I am trying to run a simulation of a 100kW system.
The system contains 1 central inverter with 1 MPPT.
However the panels have 3 orientations that are slightly different to each other.
I understand with 2 orientations, i can use the mixed #1 and #2 option, however what if there were 3 orientations connected to one tracker, is there a way to run an successful simulation?
Please let me know.
Thank you.
PostPosted: Sun Mar 20, 2016 1:44 pm
PVsyst only treats the mix of 2 orientations on a given MPPT input.
If you have 3 orientations, you should define an average between two of them. The results will not be very different.
PostPosted: Mon Feb 24, 2020 11:49 am
When do you mean with average between them? Lets consider an extreme case where we have 2 orientations: -90S and +90S. The average would be 0S (??) but the result couldn´t be more misleading.
I am trying to compare mismatch losses of central inverters and string inverters for minor differences in orientation.
Thanks in advance.
PostPosted: Wed Mar 04, 2020 11:07 pm
The simpler way is to redefine your inverter with 3 MPPT inputs, and attribute one sub-array to each input.
The mismatch between orientations (i.e. between strings in different orientations) is usually very low (a fraction of %). You can check this by defining one sub-array with a "mixed" orientation. Here the calculation is correct, as it uses the mix of both I/V curves.
