It is currently Sun Sep 20, 2020 3:42 am
PostPosted: Wed Oct 23, 2019 3:47 pm
PVSyst uses module temperature correlation given by Faiman et al which utilizes irradiance in collector plane and wind speed to estimate module temperature. The software has used some specific values of coefficients. However, is it possible to modify the coefficients of thermal model as per our own research?
Thank you
Humaid
PostPosted: Fri Dec 20, 2019 9:21 pm
Yes, just overwrite the constant loss factor Uc under Field Thermal Loss Factor in the Detailed Losses menu.
cron
