https://forum.pvsyst.com/
Coefficients of Thermal model
https://forum.pvsyst.com/viewtopic.php?f=25&t=4595
Page 1 of 1
Author:  Humaid [ Wed Oct 23, 2019 3:47 pm ]
Post subject:  Coefficients of Thermal model
PVSyst uses module temperature correlation given by Faiman et al which utilizes irradiance in collector plane and wind speed to estimate module temperature. The software has used some specific values of coefficients. However, is it possible to modify the coefficients of thermal model as per our own research?
Thank you
Humaid
Author:  dtarin [ Fri Dec 20, 2019 9:21 pm ]
Post subject:  Re: Coefficients of Thermal model
Yes, just overwrite the constant loss factor Uc under Field Thermal Loss Factor in the Detailed Losses menu.
https://www.phpbb.com/
