It is currently Sun Apr 05, 2020 5:28 am
PostPosted: Wed Aug 07, 2019 9:44 am
Hi everybody,
I have to to run a simulation of a grid connected pv plant consisting of three converter units connected in and out with internal LV/MV transformer each (380V/22000V).
Then there is a step up transformer from 22kV to 66kV inside the facility and a 66 kV OHL up to the substation where the POC is located. The OHL is almost 2km long
How can I take into account the losses of the different sections MV and HV?
Regards
Pierluigi
PostPosted: Thu Aug 22, 2019 7:15 pm
Outside of PVsyst in excel
PostPosted: Tue Aug 27, 2019 2:58 pm
Hi,
so this means that PVSyst only is able to give a result as if the POC is before the step-up transformer.
To have a realistic production forecast, I should thus calculate the loss in % due to the step up transformer and the OHL and then apply to the PVSyst result.
Do you find it correct?
Regards
Pierluigi
PostPosted: Tue Aug 27, 2019 5:44 pm
Take your inverter output from pvsyst, apply your losses from there in order to the POI
cron
