https://forum.pvsyst.com/
Yearly Orientation for stand alone pv systems
https://forum.pvsyst.com/viewtopic.php?f=25&t=4516
Page 1 of 1
Author:  amina [ Sun Aug 11, 2019 5:36 pm ]
Post subject:  Yearly Orientation for stand alone pv systems
Hi
I'm using pvsyst 6.83 for simulating a stand alone pv system for yearly fixed tilt angle orientation
the problem is the program pop only on the winter optimum angle
the yearly optimum angle in the project area is 34 degrees , the pvsyst take only the winter optimum angle which is 57
How can I fix the orientation on the yearly chose for the stand alone pv system
regards,,
Author:  dtarin [ Tue Aug 13, 2019 7:31 pm ]
Post subject:  Re: Yearly Orientation for stand alone pv systems
You can change tilt under the orientation menu (under input parameters). If you have created a 3D shade scene, you can also set the tilt there, and update the orientation settings once you save and close the shade scene.
https://www.phpbb.com/
