It is currently Thu Aug 13, 2020 1:15 pm
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Mon Apr 01, 2019 10:48 pm
Is it possible to model and simulate mono-facial and bifacial modules in the same project base on the current version?
It seems not. So will you develop this type of scenario in near the future?
PostPosted: Wed Apr 10, 2019 11:06 am
Right now it is not possible to do this in PVsyst. Since this is a very special case, there is no plan to implement this in the near future.
PostPosted: Thu Apr 11, 2019 12:57 pm
Thanks for the explaination. That option should be upgraded to make easy models.
PostPosted: Thu Apr 11, 2019 9:30 pm
Dears, to my experience as well, this is not possible yet, which is a pity.
What I am doing in the moment to get my monofacial reference (e.g. to assess the potential bifacial gain of a system) is to repeat my bifacial simulation with "don't use in the simulation" (System / Bifacial System / General Simulation Parameters).
Can someone confirm that this is the way to go?
Thanks.
PostPosted: Mon Apr 15, 2019 8:21 pm
Thanks.
That will give you the bifacial gain for the bifacial module, but not give you the gain if you were to install a monofacial module instead. Bifacial modules have different performance and sizing compared to their monofacial equivalent from the same manufacturer (from what I've seen).
PostPosted: Wed Apr 17, 2019 11:10 am
We don't envisage to develop a simulation of both options mono and bi-facial at the same time.
As these would be 2 different systems, therefore 2 different sets of result variables, etc. This involves a very complex simulation process. I really don't see how to do that in PVsyst, and how to present it on a report.
The right way is to perform 2 different simulation, and compare the results (eventually the losses, like for example the overload losses).
cron
