It is currently Mon Aug 10, 2020 1:56 am
PostPosted: Mon Aug 06, 2018 4:36 pm
What do the quantities PlAzim and PlTilt refer to?
I often get erratic values in my hourly output file such as:
PlAzim
-90
0.0014
90
PlTilt
40.365
52.692
60
36.509
9.2845
0.0009
What are these numbers indicating?
Thanks,
H.
PostPosted: Tue Aug 28, 2018 11:48 pm
These values are simply the plane tilt and plane azimuth of your tracker, at a given time.
I don's see in which way they are erratic: these are calculated from the tracker's position (phi angle, axis tilt and azimuth, depending on the tracking mode) and are quite real angles.
PostPosted: Thu Aug 30, 2018 1:22 pm
Hi André,
Thanks for the reply - I meant no disrespect!
My comment about the erratic nature was more referring to the PlAzim values. This output was achieved using a single axis tracker so I didn't understand why the azimith changed.
Thinking on it though I realize that one could interpret it as a change, and the very small 0.00014 value is when the tracker is at, or very close to the stow position - this clears up my miss-understanding so thank you.
Best,
H.
cron
