It is currently Wed Dec 01, 2021 10:36 am
PostPosted: Wed Sep 08, 2021 10:53 am
Hi
I'm trying to run my analysis using bi-facial modules set onto a ground profile. Once I have established my shading scene the model gives me the following error message 'Your PV system is not suited for the bifacial 2D model computation:' but fails to explain why.
The shading scene is correct and PVsyst has validated it, and is a direct copy of the built system I am modelling this on.
Is anyone else having this issue? Any suggestions?
Thanks in advance.
PostPosted: Wed Sep 08, 2021 4:27 pm
Hi Brian!
Did you configure the bifaciality details in the system section (button above the PV-module selection list) or did you just select the PV-modules with bifacial functionality?
Regards!
PostPosted: Wed Sep 08, 2021 4:36 pm
Thanks for the reply.
I have configured it correctly, and have modelled bifacial modules several times before without issue.
I think I have solved the issue though. My tables were inserted by auto-filling my table zone. I edited a couple of the tables manually after this to reduce the size of the tables. When I checked the details of the tables that I hadn't changed the settings had shifted in the size definitions from 'by modules' to 'by sensitive areas'. I changed the setting manually back to 'by modules' and had to adjust the number of modules per table again as they seemed to default to a number that I hadn't specified. That seemed to fix the issue. Luckily my system is reasonably small (2MWp) as anything much bigger would have taken a long time to manually change.
Not sure exactly what the underlying issue was but changing this setting seemed to resolve it.
Cheers!
