https://forum.pvsyst.com/
Project settings, shadings
https://forum.pvsyst.com/viewtopic.php?f=24&t=4920
Page 1 of 1
Author:  tecnun [ Mon Jun 15, 2020 3:25 pm ]
Post subject:  Project settings, shadings
Hello good day,
I would like to know exactly the difference between these shading conditions in Project Settings:
- Discriminating orient difference between shading planes
- Maximum orient difference for defining average spread orientation
What do they stand for?
For instance, I am working with shading scenes imported from T3 in a non-flat terrain (real topo scene). By default the system brings me to define +8 orientations. But I would like to define 3-4 main orientations and distribute them in 3-4 subarrays (unless terrain is very flat, which i prefer to define 1 average orientation-slope)
Dont know if i have explained...
BR Jose M (tecnun)
Author:  dtarin [ Wed Jun 24, 2020 1:06 am ]
Post subject:  Re: Project settings, shadings
I believe this can be thought of as the resolution to which PVsyst will define a unique orientation based on the difference with other sheds
This parameter will be used to define the range for which an average value will be calculated and used for transposition.
See: viewtopic.php?f=3&t=2524&p=6730&hilit=D ... anes#p6730
Author:  tecnun [ Wed Jun 24, 2020 12:51 pm ]
Thanks Dtarin,
I m getting now the discriminating factor, eg if you have only 2 tables and they differ each other 1° if you choose 2° the system will consider them equal, but if you set it to 0,5° there will be 2 different orientations.
Concerning the other condition i stll have doubts. So if, going to the hereabove example, you add a third table wihich differs the other 2 more than 10° and you choose limitation of 10° what happen?
BR Tecnun
https://www.phpbb.com/
