It is currently Tue Sep 22, 2020 10:08 pm
 Post subject: Shading and ground data
PostPosted: Mon Jan 13, 2020 12:56 pm
Dear all,
let me wish you all the best for this new year!
Can you please tell me if the ground data imported through CSV file is considered when computing the shading?
Regards
Christophe Vernay
PostPosted: Wed Jan 15, 2020 10:01 pm
It can be considered a shading object if you check the box in the objects properties "enable object to cast shadow" or something similar. Then it will be considered solid object. If you use it, without this check, it will still change the module placement and as such, their shading, POA, etc.
PostPosted: Thu Jan 16, 2020 3:04 pm
Thank you for your answer. Regards
cron
