It is currently Wed Sep 23, 2020 6:21 pm
PostPosted: Wed Jun 27, 2018 5:38 pm
When I import a 3D near shading scene from Helios3D, PVSyst (version 6.72) changes the azimuth angle from 0° to 1°. I can manually change it back to 0° in the Orientations menu and Near Shadings menu, but when I run the simulation again, PVSyst changes it back to 1°. I am assuming that this is a cosmetic issue in PVSyst and the actual calculations are not affected since the shading table appears to be the same, however, need confirmation that this is the case.
PostPosted: Fri Jul 06, 2018 11:27 pm
The Helios3D systems are usually defined with a baseline slope om a hill. This changes the true orientation of the plane of each table.
Please see our FAQ With tilted roofs, PVsyst changes my orientation
PostPosted: Tue Jul 10, 2018 11:06 am
maybe it is also an issue raised by "true north vs. grid north" pls see here: https://en.wikipedia.org/wiki/Grid_north
