It is currently Thu Sep 24, 2020 6:49 am
PostPosted: Mon Apr 02, 2018 4:56 pm
I am quite new to PVSyst. I am trying to make a system using single-axis tracker with hori N-S axis for a location of latitude 40 degrees. I know that I need to keep axis tilt zero but I am still trying to understand what would the axis azimuth in this case. Considering this case for the Northern hemisphere. I am assuming the face of the panels towards east-west so, in my opinion, axis azimuth should be 90 degrees ( assuming true north = 0 degrees) or whether the collector plane should face south only? Someone, please confirm.
PostPosted: Thu Apr 05, 2018 8:56 am
The axis azimuth is to be used in cases where the orientation of the axis is deviated from the North/South axis. Meaning that the pv modules axis is not aligned with the North/South axis. Typically such deviation is to be avoided when planting a new system but if the land conditions and/or obstacles do not permit so then you deviate the axis. It is always assumed that South is 0°. Hope i helped. If you need anything more let me know.
