It is currently Mon Sep 21, 2020 8:00 pm
PostPosted: Tue Jan 30, 2018 4:53 pm
when I import a 3D model of a building made in rhino to PVsyst as a .dae file, the square meter are increased significantly from the square meter area defined in rhino. This gives me trouble as whenever I want to focus my view on the building in PVsyst, I get a "Number conversion error: *192693". I figured this is because the number which is defining the position I am viewing my object from in the XYZ-plane is too high or has this star(*) in front of the number, which gives me an error. However, whenever I remove the star in front of the number I cant see my building anymore, so when I try to rotate my way back to the building, the star reappears.
So my question is, why does PVsyst increase the area (the wall is 5 square meter in rhino, but gets increased to 400 000 square meters in PVsyst)? Is there any way to decrease the whole building proportionally in PVsyst as it consists of 150 different objects?
PostPosted: Sat Feb 03, 2018 1:54 pm
What may solve this is to import in inches. I don't know if it will solve your issue though, because of the extreme size difference you describe.
Also, maybe use 3ds instead of dae, if Rhino can export in that format.
