It is currently Fri Sep 25, 2020 12:24 pm
 Post subject: Definitions
PostPosted: Thu Aug 03, 2017 3:37 pm
Does anyone know the exact definition of the following:
- Pitch (spacing plus height of the modules, or projection of such to the ground base on tilt?)
- Coll. band width (height of the modules or projection to the ground based on tilt?)
- Top/bottom inactive band
- Ground area occupatino ratio, or A(coll) and A(ground). It seems this is not equivalent to "ground cover ratio", an NREL term, correct? GCR is a comparison of horizontal projections, whereas GAOR seems to compare lengths at different angles?
Anyway, a graphic in the help section would be useful. I'm trying to guess based on the little graphic but it's hard to really tell.
-Jen
 Post subject: Re: Definitions
PostPosted: Thu Aug 03, 2017 7:36 pm
Pitch: Post to post distance
Coll. band width: width of the modules regardless of angle, i.e. if two in portrait, coll. band width is length of module * 2 + spacing between modules
Inactive band: distance the underlying structure extends past the module area. Often times this is zero.
GAOR: collector width/pitch
