It is currently Mon Sep 21, 2020 8:31 pm
PostPosted: Thu Apr 27, 2017 4:41 am
I am doing the experiment test on the effect of near shading to the energy production of PV modules over a year.
Situation 1: I put the PV modules without near shading 3D scene, the loss diagram result shows that "Near Shadings: Irradiance Loss" is 0.3%
Situation 2: I put the PV modules with near shading 3D scene, but the building block never caused any shadow on PV module, the loss diagram result shows that "Near Shadings: Irradiance Loss" is 2.4%
Situation 3: I put the PV modules with near shading 3D scene, the shadow cover part of the PV modules in the morning (8am to 11am), the loss diagram result shows that "Near Shadings: Irradiance Loss" is 3.0%
I wonder to know why i adding a building block but dont have any shadow on the PV modules that can caused a 2.4% of near shading: irradiance loss. What is the parameter that affect the losses due to near shading.
Thank you in advanced.
PostPosted: Fri Apr 28, 2017 10:38 pm
The shading is accounted for the beam component (the shade what you see), but also on the diffuse and albedo components, which are integrals of the shading factor over all the directions "seen" by the PV module.
PostPosted: Fri Jul 21, 2017 4:49 pm
This makes sense to me as far as additional shading loss considered due to lower diffuse irradiance but could you expand on the Albedo effect. Is the Albedo factor from a nearby object necessary a loss? what if the object has a white high reflecting surface?
Thanks.
