It is currently Fri Sep 25, 2020 12:06 pm
PostPosted: Fri Apr 07, 2017 2:12 am
Is it possible to modify the module type for more than one PV table at a time? Selecting multiple and pressing ctrl+m to modify does not work for me. For complex array layouts with many independent sheds, this is a very tedious task. Using 6.6.1.
Thank you.
PostPosted: Wed Apr 19, 2017 11:10 am
Are you talking about the module in the select box of the "By modules" tab ?
If yes, then you can't and it doesn't make much sense as I explained it here : viewtopic.php?f=24&t=2878
PostPosted: Fri Apr 21, 2017 1:48 am
I am referring to other parameters of a PV table/shed, like the inactive band size or module spacing.
PostPosted: Wed Apr 26, 2017 8:41 am
Okay, this is not possible yet in PVsyst.
The only things you can change for multiple fields at the same time are width and length.
