It is currently Fri Sep 25, 2020 12:39 pm
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Mon Feb 29, 2016 12:20 pm
I am new with pvsyst. I have lots of doubt regarding orientations & near shadings
can you send me step by step tutorial for given example.
I want to do simulation with single axis tracker n-s axis row to row 5 mtr pitch. module and inverter any.
please explain orientation & near shading, backtracking.
my tracker size is 12 rows with 40 modules.
PostPosted: Tue Mar 01, 2016 9:03 pm
In the Orientation part, you choose "Tracking, tilted or horizontal tracking axis".
If your trackers are horizontal, you set "Axis tilt" = 0.
You can check "Backtracking" if you want to use this strategy.
You define your system (array with PV moudles and inverter(s).
Then in the "Near shadings" 3D editor, you create your array by choosing "Object > New > Tracking PV planes", and you define the same parameters as in the "Orientation part.
You can follow the tutorial present in the software (just below the "Help" in the menu), especially the part dealing with the shadings scene construction. This doesn't concern a tracking system, but the principles are the same.
PostPosted: Wed Mar 02, 2016 4:53 am
Thanks for your best reply.
Can you tell me at which location i have to enter my
row to row pitch? In backtracking what is pitch & coll. width shows.
In near shadings i have to draw all modules?? or tracker blocks?? because for 125MW plant contains lots of trackers. please give detailed explanation.
PostPosted: Sat Mar 05, 2016 12:38 pm
Can anyone explain this?? I too have similar issues.
PostPosted: Mon Dec 18, 2017 9:15 pm
Same. I tried using "Unlimited Horizontal Tracking" but I can't be sure that is a system using N-S axis trackign east to west. None of the other single axis tracking options allow me to input a pitch. Please advise.
PostPosted: Fri May 11, 2018 9:31 pm
Now that we have members with their produced M5s on boats headed for the US, heres a bump for the information in this thread.
Happy tracking
