It is currently Fri Feb 26, 2021 2:26 am
PostPosted: Fri Jun 28, 2019 10:55 am
did I correctly enter the module's data into the database? Energy production results seem too low.
Module Q.CELLS Q.PEAK DUO L-G5.2 400
Manufacturer data sheet:
My PVSyst module data tabs:
I have not changed other tabs.
Exported to excel: http://pliki.domrel.pl/PVSF/qc.xls
Should I improve something???
PostPosted: Fri Jun 28, 2019 6:47 pm
It looks like you are missing the cell dimensions in the PAN file (122.2 cm^2 is my guess based on the 390W). Verify you have the correct power temperature coefficient Pmpp. Also your Rshunt G=0 & Rsh dont match the 390W PAN file.
PostPosted: Mon Jul 01, 2019 2:17 pm
Thank you for your interest and answer.
Currently, the module parameters are as follows:
PAN file:
Code:
PVObject_=pvModule
  Version=6.81
  Flags=$0743
  PVObject_Commercial=pvCommercial
    Flags=$0041
    Manufacturer=Hanwha Q Cells
    Model=Q.PEAK DUO L-G5.2 400
    DataSource=Manufacturer 2019
    YearBeg=2019
    Width=1.000
    Height=2.015
    Depth=0.035
    Weight=23.500
    NPieces=100
    PriceDate=27/06/19 11:19
  End of PVObject pvCommercial
  Technol=mtSiMono
  NCelS=72
  NCelP=2
  NDiode=3
  GRef=1000
  TRef=25.0
  PNom=400.0
  PNomTolLow=0.00
  PNomTolUp=1.40
  Isc=10.240
  Voc=49.00
  Imp=9.750
  Vmp=41.04
  muISC=4.00
  muVocSpec=-140.0
  muPmpReq=-0.360
  RShunt=400
  Rp_0=1600
  Rp_Exp=5.50
  RSerie=0.212
  Gamma=0.977
  muGamma=-0.0005
  VMaxIEC=1500
  VMaxUL=1500
  Absorb=0.90
  ARev=3.200
  BRev=12.288
  RDiode=0.010
  VRevDiode=-0.70
  AirMassRef=1.500
  CellArea=122.2
  SandiaAMCorr=50.000
End of PVObject pvModule
Is it OK now? Production has improved :)
PostPosted: Mon Jul 01, 2019 6:55 pm
The Rsh and Rshunt exponential are different in my 390W PAN file, but that's not to say yours are incorrect. As long as you have your own 390W PAN file to go off of, it should be ok.
PostPosted: Tue Jul 02, 2019 3:27 pm
Thank you. I will leave it as it is.
