https://forum.pvsyst.com/
Downward compatibility of PANs (6.8.x --> 6.6.x)
https://forum.pvsyst.com/viewtopic.php?f=23&t=4463
Page 1 of 1
Author:  eherz [ Tue Jun 18, 2019 10:15 am ]
Post subject:  Downward compatibility of PANs (6.8.x --> 6.6.x)
Is it possible to create PAN-files with PVsyst-versions 6.8.x which can be used in former versions (younger then 6.4.x but older then 6.8.x)?
If I use the save mode "File compatible with older versions < V6.40", not all features (e.g. IAM-values, Twin-half cell design etc.) are saved.
Would be nice if an additional save mode could be implemented for >V6.40 and <V6.80.
Thanks
Author:  eherz [ Wed Jan 15, 2020 11:15 am ]
Post subject:  Re: Downward compatibility of PANs (6.8.x --> 6.6.x)
By reading and try and error, I found the solution:
PANs saved with >V6.8.0 are encoded with UTF-8, this format cannot be read by >V6.4. Therefore you have to change the coding (e.g. with Editor).
https://www.phpbb.com/
