It is currently Fri Feb 26, 2021 2:30 am
PostPosted: Sun Jul 15, 2018 11:42 am
Hi Andrew
I am trying to simulate Bi-facial modues , but having few query regarding the same
1) Is it necessary to select the unlimited shed in the Field type in the orientation tab for simulation of Bi-facial modules ?
2) can we simulate the bi-facial module with fixed orientation or several orientation if we design 3D for the same ?
Please refer the attached image for the same.
Thanks
Nitin Panwar
PostPosted: Mon Jul 16, 2018 11:28 pm
Hello Nitin,
I do not believe bifacial simulation for use with 3D scenes is yet available, and must use unlimited sheds at the moment. 1) Yes. 2) No
See: viewtopic.php?f=24&t=3544&p=8825&hilit=bifacial#p8825
PostPosted: Thu Jul 26, 2018 1:06 pm
Thanks Solar Guru for your reply.
I have another query regarding the below mentioned points.
Structure shading factor (default value is 5%) -
1) On what parameters basis the shading factor is taken as 5 % only ?
Mismatch loss factor (default value is 10%)
1) What does mismatch at back side of modules means and why this value is taken 10 % as default ?
Thanks
PostPosted: Fri Aug 10, 2018 6:50 pm
Thanks
This value has been updated to a default if 5% (as of v 6.7.4 I think), as it was believed to have been overestimated @ 10%.
I dont have any info on the shading loss factor, so can't help you there.
PostPosted: Fri Aug 17, 2018 11:54 pm
It is sometimes useful to read the Help ...
See "Project design > Bifacial Systems > Bifacial systems procedure"
