It is currently Sat Feb 23, 2019 12:37 am
PostPosted: Fri Jul 28, 2017 3:14 am
Is it possible to define multiple Plane Tilt and Azimuth for ONE inverter?
For example, A inverter have 100 strings, 40 strings are on Tilt 10°, 60 strings are on Tilt 20°.
Regards.
PostPosted: Mon Jul 31, 2017 10:38 pm
It depends on the inverter. You can use multi-MPPT function and create three subarrays, one for each orientation.
PostPosted: Thu Aug 03, 2017 2:39 am
Thank you for your reply,
I understand that I can define two Plane Tilt for one inverter.
Is it possible to define over three Plane Tilt and Azimuth for one inverter?
PostPosted: Thu Aug 03, 2017 2:48 am
Yes, by using the multi-mppt feature on the inverter, you can. If your inverter does not have it built in, you will need to add it yourself by modifying the OND file. Here is some discussion on the feature:
viewtopic.php?f=3&t=2668&p=7107&hilit=multi+mppt#p7107
PostPosted: Thu Aug 03, 2017 5:15 am
I mistood how to use multi-MPPT.
I will read the post and try to use multi-MPPT inverter.
Thanks.
