It is currently Wed Sep 23, 2020 3:33 pm
Post new topic  Reply to topic  [ 7 posts ]
 Post subject: Module Quality Loss
PostPosted: Fri Sep 07, 2012 2:42 pm
Most high quality modules these days have a positive tolerance for nominal power. However, the factory flash tests themselves generally have a tolerance of +-3% and thus the nominal power may be less than the flash test result.
Should this flash test tolerance generally taken into account in the Module Quality Loss input?
Regards
Andrew
 Post subject: Re: Module Quality Loss
PostPosted: Sat Sep 29, 2012 7:54 pm
Taking the flash-test uncertainty into account in this parameter would be equivalent to a "Worst case" choice.
By respect to the factory flash-tests, you can also take the eventual LID losses into account.
Please see my comments on How to define the "Module Quality loss" parameter in the FAQ
PostPosted: Tue Nov 04, 2014 12:42 pm
Hi Andre,
In version 6, both tolerance limits are specified, and PVsyst will choose a quarter of the difference between these values. For example, with -3..+3%, it will be 1.5%, and with positive sorting 0..+3%, it will be -0.75% (i.e. a gain).
This module quality loss we have to manually enter or automatically PVSyst will take the right value. We actually manually entering this value till now. Please clarify.
'a quarter of the difference between these values' on which basis this calculation?- Please Clarify
Thank you
PostPosted: Thu Nov 06, 2014 7:40 pm
As explained in the FAQ:
- At the creation of a calculation version, the Module quality loss is pre-defined at a value according to the module's tolerances. This is a default value.
The quarter of the value between Min and Max tolerance is my own choice.
- This parameter is at your disposal: you can change this value for taking any other phenomenon into account, according to your requirements or your judgement.
PostPosted: Mon Nov 10, 2014 8:35 am
If module has only positive tolerance, we have to give module quality loss = (-ve) to 0 or we can give (+ve) also.
Please clarify.
PostPosted: Mon Nov 10, 2014 6:27 pm
The parameter for the module quality represents a loss.
Therefore if it is positive, it will lead to a loss, and if it is negative, it will produce a gain during the simulation.
For example for a module specified as (+0 .. +3%) tolerance, the default value will be -0.75%.
PostPosted: Tue Nov 11, 2014 6:41 am
ya. thats fine.
what i am asking is "If module has only positive tolerance, there will be gain only know?"
Please Clarify.
