It is currently Mon Dec 06, 2021 1:52 pm
 Post subject: LG Chem Batteries
PostPosted: Fri Dec 21, 2018 9:35 am
Good morning,
Does anyone have the .BTR files of LG Chem's lithium batteries? (RESU3.3, RESU6.5, RESU10, RESU7H and RESU10H)
Thank you very much.
Best regards!
 Post subject: Re: LG Chem Batteries
PostPosted: Wed Oct 27, 2021 8:57 am
Hi,
For Li-Ion batteries, this is not so simple. For defining a battery pack, you should define a single cell, and then construct the battery pack as an assembly of these cells.
Constructing the cell's file requires to avail of detailed datasheets of this cell. And the elaboration of the parameters passes by a detailed analysis of these data (especially the charging / discharging curves)
The best way is to start from an existing cell's file, of the same technology (chemistry).
NB : The battery model is fully described in the Help " Physical models used > Batteries - General model description"
And also " Component Database > Batteries > Batteries - Main interface > Batteries - Basic data (Lithium-ion)" and subsequent topics.
_________________
Best regards | Cordialement
Lazare Fesnien – www.pvsyst.com
