It is currently Wed Aug 12, 2020 11:20 am
PostPosted: Tue Nov 26, 2013 2:35 pm
Description
If you already used and saved data under PVsyst 6 on a old computer and would like to switch to a new computer, there are 2 things to do:
- transfer your license (if you have one)
- export data from the old computer and import them on the new one
Export data from old computer
- Plug a USB key in the old computer.
- Start PVsyst.
- Go to main menu >> File >> Workspace >> Export...
- Set the path to the USB key to export data and switch on "Compress exported workspace", then click on Export
This procedure will create file PVsyst_ExtData.zip containing all your PVsyst data on the USB key.
Import data on the new computer
- Plug the USB key in the new computer.
- Start PVsyst and accept the default options when asking where to find a data workspace.
- Go to main menu >> File >> Workspace >> Import...
- Set the path of the exported zip file PVsyst_ExtData.zip (on the USB key)
- Set a new workspace path, for example C:\Users\<your_windows_name>\PVsyst_Import, then click on Import
PostPosted: Wed Nov 18, 2015 11:33 am
Note that you can use the same procedure to backup or archive your PVsyst user data:
1. Use the export full workspace to backup your data in a zip file
2. Use the import full workspace to restore your data from a zip file in case you had for example a disk failure.
