It is currently Tue Aug 04, 2020 9:51 am
Post new topic  Reply to topic  [ 15 posts ]  Go to page Previous 1 2
 Post subject: Re: Import files
PostPosted: Fri Jan 20, 2017 4:18 pm
Hi all,
anything new about this ?
there is a lot of free .lsp to extract points coordinates from dxf / dwg format to csv.
that would be a good start to have a feature that can import 2D or 3D from csv. even we have to redesign the faces of the polygon.
well thx for your reply,
PostPosted: Wed Jan 25, 2017 11:21 am
We have implemented the possibility to import files from Sketchup using the open DAE (Collada) file format, and therefore from AutoCAD (using FBXConverter).
This will be available in version 6.60 which should be published soon.
You can already import a CSV topography in the shading scene using the menu "File > Import > CSV ground data". But this is intended to import topography, not 3D objects.
PostPosted: Thu Jun 07, 2018 5:33 pm
Running into some issues when trying to import a .dae file, originating from autocad. Ive gone through the process of converting from: .dxf>.fbx>.dae using the Autodesk FBX Converter tool as mentioned in the help topics. The issue is that, when imported, its showing 0 Faces, 0 vertices, 0 objects. I had some luck with one particular .dae file, showing me 2 faces, and giving me the selection option on the additional tab of "Materials". But when that one was imported, it pulled two oddly shaped rectangles that had 0 correspondence with the actual design. Im at a bit of a loss here since re-creating a actual layout in the construction window is extremely tedious, time consuming, and often resulting is failure to replicate. Ive followed the help topics for importing from Sketchup and Autocad, but it doesnt seem to be granular enough. Any assistance is greatly appreciated.
Also open to suggestions to replicating a designed array in the construction/perspective tab. One that falls outside of a typical rectangle.
 Post subject: Import files
PostPosted: Mon Feb 18, 2019 6:02 am
There should be a way to import custom color pallets. For example I would like to use Copic’s pallets. If there isn’t a way to import this, can you please add to future release?
PostPosted: Wed Apr 22, 2020 7:00 pm
Je reviens sur ce forum, j'ai acquis un scanner 3D qui créé des nuages de points.
J'ai vu que vous allez bientot sortir la version 7
avez-vous intégré dans la version 7 de votre logiciel la possibilité de récupérer ce nuage de point (au format E57 par exemple bien que la taille de ce nuage est très importante)
à défaut, avez-vous comme projet la possibilité d’importer des batiments modélisés au format IFC (déjà demandé depuis 2013)
ou aussi la possibilité d’import un fichier maillé sz type « mesh » au format obj ?
