JMcIntosh Posted April 4, 2016 Posted April 4, 2016 The latest guidelines from SolarEdge indicate that string sizes may be up to 15,000 w. PVsyst V 6.43 does not allow oversizing. What parameters do I change to increase the allowable wattage on a SolarEdge optimizer string?Thanks in advance
André Mermoud Posted April 5, 2016 Posted April 5, 2016 Solaredge has not shared theid latest Guidelines with us. However I don't understand well which limitation you are speaking about. Please give a screenshot of window in error, and the exact error message.
JMcIntosh Posted April 5, 2016 Author Posted April 5, 2016 The latest design guidelines from SolarEdge on the newest 3-phase inverters can be found here: http://marketing.solaredge.com/acton/ct/8801/s-0783-1603/Bct/q-0047/l-0045:e06/ct1_0/1?sid=s3KKU5ipp
JMcIntosh Posted April 5, 2016 Author Posted April 5, 2016 Here is a screen snip showing the 20 optimizer limit. The newest guidelines would allow 25 optimzers per string 15,000 / 300 / 2 = 25. The data sheet indicates a max of 30 optimizers per string. It can be found here. http://www.solaredge.us/files/pdfs/products/power-optimizers/se-P5-series-commercial-add-on-power-optimizer-datasheet-na.pdf
André Mermoud Posted April 10, 2016 Posted April 10, 2016 We have to get instructions from SolarEdge for modifying the installing conditions (which have been established in close collaboration with the manufacturer). We are in touch with them.
SE2015 Posted May 27, 2016 Posted May 27, 2016 A current workaround to this limitation is to design shorter strings, just for the PVsyst simulation (in practice you will install with the over-sized strings). This will have no effect on the simulation.So for example: you want to design an SE27.6K inverter with 3 strings of 22 power optimizers (each optimizer connecting to 2 modules in series, so the result is 66 power optimizers = 132 modules). PVsyst perhaps limits the string length to 18 optimizers, so you could instead specify 6 strings of 11 power optimizers, giving you the same result (66 power optimizers/132 modules).Any mathematical combination will work, as long as you get the number of modules you want.See the attached image.
aaronrodg Posted December 2, 2016 Posted December 2, 2016 The latest design guidelines from SolarEdge on the newest 3-phase inverters can be found here: http://marketing.solaredge.com/acton/ct/8801/s-0783-1603/Bct/q-0047/l-0045:e06/ct1_0/1?sid=s3KKU5ipp Great work!
SolarJ Posted December 7, 2016 Posted December 7, 2016 Has there been any movement on extending the power optimizer definitions inside the software? I can not go beyond 19 with a 72 mono when design guidelines define the use of 20.
aaronrodg Posted February 7, 2017 Posted February 7, 2017 Yes give some idea on it i am also waiting....
