When I hit "load project" the same nine errors pop up each time before I am able to select a project to load. The following are the errors:
Conversion error of string "d"=>Real
Conversion error of string "R3}{
Conversion error of string "-F}{
Conversion error of string "}{"=>Date The string is empty or not sufficient
Reading project "oH}{
Reading project "
Reading project "
When the errors pop up and I can hit either ok or cancel to each and they will all go away and I can continue my work. However I am hoping there is a way to get them not to pop up at all.
Your project file (and probably the associated calculation verions) is corrupted.
This usually arises when you try to read a file which has been elaborated from a more recent version of PVsyst.
In this case you have to remove the corrupted files from your workspace.
