sajeedmirza84 Posted February 29, 2016 Posted February 29, 2016 Hi,I am new with PVsyst. I have lots of doubt regarding orientations & near shadings can you send me step by step tutorial for given example.I want to do simulation with single axis tracker n-s axis row to row 5 mtr pitch. module and inverter any.please explain orientation & near shading, backtracking.my tracker size is 12 rows with 40 modules.
André Mermoud Posted March 1, 2016 Posted March 1, 2016 In the Orientation part, you choose "Tracking, tilted or horizontal tracking axis". If your trackers are horizontal, you set "Axis tilt" = 0.You can check "Backtracking" if you want to use this strategy. You define your system (array with PV moudles and inverter(s).Then in the "Near shadings" 3D editor, you create your array by choosing "Object > New > Tracking PV planes", and you define the same parameters as in the "Orientation part. You can follow the tutorial present in the software (just below the "Help" in the menu), especially the part dealing with the shadings scene construction. This doesn't concern a tracking system, but the principles are the same.
sajeedmirza84 Posted March 2, 2016 Author Posted March 2, 2016 Thanks for your best reply. Can you tell me at which location i have to enter myrow to row pitch? In backtracking what is pitch & coll. width shows. In near shadings i have to draw all modules?? or tracker blocks?? because for 125MW plant contains lots of trackers. please give detailed explanation.
astha.saxena542 Posted March 5, 2016 Posted March 5, 2016 Thanks for your best reply. Can you tell me at which location i have to enter myrow to row pitch? In backtracking what is pitch & coll. width shows. In near shadings i have to draw all modules?? or tracker blocks?? because for 125MW plant contains lots of trackers. please give detailed explanation. Can anyone explain this?? I too have similar issues.
gonecrawfishin Posted December 18, 2017 Posted December 18, 2017 Same. I tried using "Unlimited Horizontal Tracking" but I can't be sure that is a system using N-S axis trackign east to west. None of the other single axis tracking options allow me to input a pitch. Please advise.
Justinamach Posted May 11, 2018 Posted May 11, 2018 Now that we have members with their produced M5s on boats headed for the US, heres a bump for the information in this thread.Happy tracking
