Inverter rating in kW or KVA
phomer
When the inverter is able to produce reactive power (i.e. able to produce a phase shift), the Nominal Power (PNom) may concern
- either a limitation in Active (real) energy, expressed as [kWh]
- or a limitation in Apparent energy, expressed as [kVA]. This limitation is rather usual as it is equivalent to an output current limitation.
This is a a property of the inverter, therefore a choice in the definition parameters.
