How to add new Inverter in PVSYST
You can try to import this device from PHOTON if it is existing there ("Databases > Inverters > button "Import from PHOTON").
You can also create a new component from scratch, using the infomation of datasheets.
But the easiest way is to open an existing similar device, modify its parameters according to the datasheets, and save it under a new file name.
  • 6 years later...
