Adding decimal places to collector plane orientation
For the next version is it possible to add 1 decimal place to the collector plane orientation.
Often we want 17.5 but when the simulation runs it will say 17 or 18.
In addition to this it only seems accurate if its the last number you input before running the simulation.
  • 2 weeks later...
We consider that defining the angles with 0.1° accuracy doesn't make much sense, neither in the reality nor for the simulation results.
Did you ever try to position a solarimeter or a module with an accuracy better than the degree in the space ? This is very difficult indeed without sophisticated scientific instruments.
