how to model 2 MPPT with shared DC side and with different strings
I like to know in PVsyst how to model an inverter with 2 MPPT. One MPPT has (5) strings and one MPPT has (4) string. And two MPPTs have a shared (not independent) DC side. see attached figure.
thanks.
Jie
inverter - mppt - string connection
2026201257_pvsystmppt.JPG.e4c2ecf885028b574c3c3187bb76c156.JPGIf the inverter has MPPT capability then PVsyst will give you the option to choose whether to use it and how many MPPT inputs to use (2, in your case). Then I believe you would just choose to have 9 string inputs, which PVsyst would automatically distribute between the two inputs. See the highlighted portions of the attached image. Hope that helps!
  • 3 weeks later...
The solution proposed by Jen H is quite correct.
You could also define 2 sub-arrays, each with one MPPT input: one with 5 strings and one with 4 strings.
This would be the solution if you defined groups of strings with a different number number of modules in series.
